Hi there,
rhino doesn’t open my file TNM144 - opzet.3dm (5.7 MB) . I have recently updated 6.17 => 6.18. How can I roll back to 6.17 on OSX?
best regards,
Tim
Hi there,
best regards,
Tim
Opens here in Windows Rhino 6.19 Release candidate… there are 67 linked block definitions that are missing. Maybe Rhino is hanging trying to find one or more of those?
Hi, @Helvetosaur,
thanks for your reply. The file used to open in version 6.17, so I am just looking for a way to continue production for now.
If I can roll back to 6.17, I should be able to embed the linked blocks or make a list of all the linked files that might cause the issue.
best regards,
Dag Tim - you can download SR 17 from this link. Please let us know if that lets you open that file.
Dankjewel Wim,
I am very confused now.
I could open the file with SR17 from the link you send me. However, I noticed I was able to open in SR18 after I opened with SR17 first. I tried to set up a reproducible sequence of actions, however, after a few times opening and closing the file with both SR17/SR18 I couldn’t open anymore with SR17 either.
Could it be related to the search paths and some global application settings that are used by different rhino applications? Anyway i’ll keep trying to isolate the problem
Thanks for that, Tim.
Are both SR17 and SR18 consistently crashing on you now when you open your file?
Does Rhino leave any trace - crash reporter, error message, …?
Hi Wim,
“good” news: I created a file without linked blockdefinitions that I can no longer open with 6.17 or 6.18 afzuigkap.3dm (4.4 MB) .
I don’t see any crash report or error messages when trying to open it. The problems started when I tried adding a layer with rhinoscriptsyntax.
Best regards,
Hoi Tim,
the bad news is that this file opens without problems here on Mac 6.17 and 6.18.
Do you have any custom start-up scripts or plug-ins that might be getting in the way? Please run the Rhino SystemInfo command and post the result here.
Hi Wim,
see my system settings attached systemInfo.txt (2.5 KB)
I have cleared my “startupcommands” that I normally use to run custom startup scripts.
I have some new info:
To me it seems the issue is related to a global setting that is used by different versions of Rhino, and the filesystem/filename.
Hi @wim,
After months I tried some options. It seems I have solved the problem by resetting the preferences. https://wiki.mcneel.com/rhino/mac/resetprefs. I guess one of my scripts was the cause. Anyway thanks for your help.
cheers, Tim
Thanks for that update, Tim!
And good to hear that you were able to solve the issue!
