This is what I’mlooking at right now, from Origin PC, though im going with a the slightly lower res monitor since i have a 4K monitor at home when i need it:
EON17-X 10 Series Pro - Single GTX 1080 — $3,917 (Customizable)
17" QFHD 3840 x 2160 17.3" IPS G-SYNC Matte Display
Graphic Cards: Single NVIDIA GeForce GTX 1080 8GB [VR Ready]
ORIGIN PC Professional Graphics Card Overclocking
Processors: Intel Core i7 7700K Quad-Core 4.2GHz (4.5GHz TurboBoost)
Memory: 32GB ORIGIN PC Approved DDR4 2133MHz (2 X 16GB)
Operating System: MS Windows 10 Professional
m.2 SSD Option: m.2 SSD OS Drive
m.2 SSD Drive: 250GB Samsung 960 Evo PCIe NVMe m.2
Hard Drive: 1TB Samsung 850 Evo Series
The only laptops I would ever recommend are the thinkpads. One of the p
models.
All the other brands might have nice specs but they all fail eventually and
servicing them is extremely difficult if not impossible.
I decided to ditch the laptop idea as I found myself at the same desk all of the time and i didn’t have to travel as much - working in coffee shops didn’t work!
I bought the desktop from https://www.scan.co.uk/ - really handy configurator to see what’s what, even if you use it and then go elsewhere for the parts.
Before I settled on the desktop I decided against renewing my MacBookPro and bought a decent set up from http://www.eurocom.com - which also has a decent configurator too.
The main issue I had was the heat… Using the laptop in a cold room on a desk and running Keyshot sent the temperature sky high to over 95 degrees. I had to send it back after a week or so…
I was caught between Alienware(Dell) - Dell (Main brand), MSI and Eurocom.
Make sure you don’t go totally balls to the wall with the power or you might end up baking it!
Seems a lot of folks are saying that Xeon/Quadro combo may not be worth the extra loot. Was this for a desktop or laptop? And what did you go with in the end? Thanks!
@Alan_Farkas what machine and setup did you decide on finally? I like Origin PC, but really need 15" because I have to travel often and 17" is beastly huge. I will also have Rhino+Vray setup.
@cartermarino I went with Acer Predator 17. Works well. I may have an issue with my GPU, but I don’t think it’s any sort of incompatibility with Rhino. Just a good 'ol computer hardware snafu.
Vray is really great with Rhino. I’m excited for it to update for the v6 platform.
