Hi!
I am struggling with setting a CPlane inside a detail. If I use standard construction plane method, everything is fine, but as long as I use universal construction plane, I am unable to match/align the view in the detail with this CPlane. Meaning going inside the detail > selecting CPlane from the named CPlanes panel > running plan command = nothing happens. While using standard construction plane, view is aligned…
edit: I got a crash when trying to run plan command in Rhino7
4 - when I try to activate the CPlane now, nothing happens, the World Top Cplane remains active, so I cannot match the view with the page
5 - I must go to the settings again, set Standard Cplane mode
Hi Petumatr,
This is a bug in Rhino. It is already on the You Track system as RH-40676.
You can register on YouTrack and flow along with the progress of the bug.
This unwanted behavior shows up on both Rhino for Windows and Rhino for Mac, too.
We will let you know here on the Forum when this issue is fixed.
Thanks for reporting this.
Sincerely,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
