I created one complex geometry of plane surface, but it had a lot of gaps between each plane surface. So I converted the geometry into mesh, and I filled the gaps. But I wanted the filled mesh geometry to have surfaces rather than mesh. So I converted the mesh geometry into NURBS surfaces. However, the geometry has had a lot of NURBS surfaces rather than plane surface. I was just wondering if the NURBS surfaces could be changed to plane surface without the gaps.
I bet there is way to fill those gaps without converting to a mesh. Could you share some screenshots and/or a 3dm file?
With that said, it’s easy to go from NURBS to Mesh but it’s much more difficult to go from Mesh to NURBS. The new Rhino 7 release has a command called QuadRemesh which makes it easier to convert meshes into NURBS. Here are some articles on this topic.
MergeAllCoplanarFaces will merge all coplanar surfaces of a polysurface into single trimmed surfaces. Note that this command only works on a polysurface. Individual surfaces need to be joined into a single polysurface to use it.
It is almost always better to stay working with NURBS surfaces rather than convert to meshes if the final result needs to be NURBS.
Thank you very much for replying.
I tried to to do what you had told me, but it did not work straightforwardly
Could you elaborate your explanation, please?
Did you use actual “untrim” to either of Surface 1 or Surface 2, or both of them?
“Untrim” worked to Surface 2, but it did not work to Surface 1, when I tried.
Did you also use “Extend Surface” or “Trim”? I would like to get the details of how you did it.
Thank you very much for making the video.
Extending the surfaces by 400 worked, interestingly.
However, how could the two edges be selected at the beginning?
