Copying Worksession Objects with Material Properties
Coming with another worksession question - when copying an object from a worksessioned model, is it not possible to retain any properties? I’m copying an object that I want to edit in my active model, but it loses material and mapping properties - this seems odd to me sense worksessioning imports all of the linked models’ materials anyways. Is there any way around this aside from opening the linked model and copying from there? It get’s a little frustrating because even selecting the original, worksessioned object won’t display the assigned material, making it a bit of a crapshoot when trying to re-assign things in this fashion.
Generally what are the rules of copying from worksessions? Is it safe to assume that only geometry will be copied, with no attached properties? It seems even blocks copied over remain on the host layers and there for dissapear when the linked model is turned off
