I know this is going to be an embarrassingly simple question, but here goes!
I have a sunshade canopy I have made in Rhino 6 that consists of flat surfaces, I would now like to use Clayoo to put some creases into the surfaces. How do I convert the Rhino model to a Clayoo model so that I can use he emboss feature?
Thanks.
Paul
Hi @Paul_Adams,
If I understand correctly, you want to convert the Rhino surface into a Clayoo object.
To do that, use the command _ClayConvertSurface, choose the segments you want in both axis, and check the Delete Original checkbox to preview the final result. There you go!
Let me know if you have any problem, or this is not what you are looking for.
Cheers,
