A basic question. If I have a surface created in rhino, in this case the hood from a car, can I put dents in the surface using Clayoo?
Or is it possibly to accurately recreate the surface in Clayoo so that it will fit seamlessly with the Rhino car model?
Hi Paul,
You can use Clayoo objects as dents, and then use a boolean to merge it.
The other way is to convert the current surface into a Clayoo object (_ClayConvertMesh). If it is a clean surface (not trimmed or booleaned) the result will be good. If need high accuracy, use quite of segments when converting.
Cheers,
