Control Point Help
Hello, I’m currently learning how to use Rhino in preparation for school this fall.
At the moment I’m trying to figure out why I can’t get control points that “box” the plane like they do in the tutorial. Any pointers on where I’m going wrong would be greatly appreciated. Thank you.
From my Rhino:
From Tutorial:
By default, Rhino uses extrusions for light weight modeling.
In this stage you can:
_Explode
_ToNurbs
And for future surfaces turn of extrusions with the command
_UseExtrusions
I see, thank you for the help.
I’d also recommend turning on the control polygon while editing, since it makes it much easier to see how each point is influencing the surface. Making small adjustments instead of large moves usually gives a much smoother result too.
