Hi @Pascal,
i’ve found a funny bug using Rhino 7.12 (Windows 10). Please use these steps to repeat:
First, open Rhino, draw some lines and Press F2. The Command History Window font is looking OK, mine look like this:
Open the Rhino file attached below, it should give you this warning:
After clicking the OK button, press F2 again and note the Command History font, it now looks like this:
I need to open another file to get back the normal font used in this window. It seems that the font substituion Rhino performed messed up the UI. The fonts are part of some chinese dimension styles which i’ve left in the example file:
ProblemFile.zip (4.8 MB)
thanks,
c.
