Hi, during reporting previous bug, I found out, that you can’t use cmd+C to copy from Command History. Instead of copiing the command it runs “'_CopyToClipboard” even when nothing is selected. Commands can be still copied by right click/Copy, but It’s quite a pain. It worked normally in V5.
Hi morris, thanks, I’ll check this.
@morris your image looks like an earlier service release, maybe? Can you run SystemInfo and copy/paste the results here.
Here in our latest, F2/CommandHistory allows Ctrl-C
Hi, I think I’m on the newest release (please see attached file). I tried the F2 memu and it works. Problem happens only if I open the menu from the bottom left icon (which I’m used to).
systeminfo.txt (4.8 KB)
Perfect! Thanks a lot!
