in the commandbar it is no longer possible to copy the command, neither CMD A nor CMD C work.
pasting with CMD V seems to work as usual.
that issue started with the last update, though i skipped one in between so not sure which one, i have now (8.6.24079.11002, 2024-03-19)
Japhy
(Japhy)
2
I quick test on our daily build isn’t showing this. I’ll roll back and try to replicate.
I tried several ways:
During a command copying the value.
Copying the actual command text.
Can you post your Rhino SystemInfo? Thanks
thanks for checking!
maybe its the way i have Rhino Set up which causes it
here my info
Untitled.txt (5.0 KB)
screenshot
wim
(Wim Dekeyser)
4
It sounds like this got fixed in yesterday’s release:
sounds like it yes, thanks @wim
