Closed document with Block Editor still open, now file is blank!
Hello guys,
So I closed a Rhino 7 file while still in Block Editor, saved the file. Now that I open it again, it is still in Block Editor, but after I close the editor there is nothing in the file. I cant select, unhide, or zoom anything. Even the set of table and chairs that’s the edited block disappears. I also didn’t find an autosaved file in the proper folder. I copied the file, and when I open the copy its the same story. The file still is 135 MB, its just blank.
Any ideas on how to get out of this predicament?
Thank you in advance.
PS: Bellow a screenshot of the document as soon as I open it.
Can you please send a copy of the file?
You should be able to go to your Windows Recycle Bin, find a recently deleted Autosave file for this model, and restore it.
That should still have the rest of the file.
Any luck?
There are a couple ways to rectify this. The one that comes to mind is to go to plugins and disable the block edit. Open the file and then save. Open Rhino again and re-enable the Block-Edit plugin.
This happened to me multiple times already. Now in a particularly annoying moment.
The suggested method of Japhy did not work for me in Rino 8, Mac, latest version.
Any other suggestions?
This is a huge issue!
It happened to me as well now several times and crashed some major project files.
The suggested solution only worked half way for me. Good approach though. When I disable BlockEdit I can use the file as usual but as soon as I enable BlockEdit again the command window is popping up again and when I close it everything goes blank again.
I found a solution but it’s not elegant at all and is quite time consuming. Usually no objects can be edited during BlockEdit but when this issues appears - in my case - everything can be edited normally except for blocks because the BlockEdit is already running. So I unlocked all layers, made them all visible and copied everything to a completely new file. The same I did with all layouts.
Really not a great way but at least I managed to save the data.
Would be great if this could be solved more easily in future Rhino versions.
This has been resolved in the 9.0.26151.06305 and beyond.
Ah great! Thanks a lot.
Will there be also an update for Rhino 8?
Hi Raphael -
The plumbing behind the BlockEdit command was completely redone in Rhino 9. This is not something that can be back-ported to Rhino 8.
