Clipping plane works in one view, does not work in other views
Hey, as shown in the video, the clipping plane only works on top view, somehow it does not work in other views. It works normally before, not sure what I have changed. thank you !
With the clipping plane selected go to the Object Properties panel, from there select Clipping Plane Properties. Then check the views you want it to be active in:
worked! thank you, Nathan!
