Clipping Plane Known Issue?
When I create a clipping plane in one view, it doesn’t always work in all views. Is this a known issue?
Thanks,
Sam
Quoting from the V5 Help file:
“Creates a clipping plane object that represents a plane for visibly clipping away geometry in a specific viewport.”
(My italics)
Hi Sam- clipping is per viewport, and you can edit which views are clipped in the clipping plane’s Properties.
I’m pretty sure that is by design. However you can enable the clipping plane in the other viewports under its properties. There is also a “flip” option available.
Edit: Pascal was faster…
He’s tricky too!
I see the property options now, thanks!
Sam
