I have found a bug that I am able to recreate. If a clipping plane is set to only clip certain layers (i.e. layer 1), it will also stop me from dragging using Osnap on objects on different layers (i.e. layer 2), that would be clipped if on the clipping plane’s assigned layer (layer 1).
Hi Gregor,
Can you provide your Rhino SystemInfo (via Rhino command line), as well as a small example that replicates what you are seeing. Thanks.
hi @Gregor_Tillman
I can reproduce the issue here, thanks
RH-83919 Osnaps don’t work behind clipping section
RH-84271 is fixed in Rhino 8 Service Release 14
RH-83919 is fixed in Rhino 8 Service Release 14
