Can't snap when dragging an object in rhino!
Hi everyone,
I have a problem that prevent me from going any far in the modeling process, its about Osnaping, when i try to select or draw from an object, it works perfectly, but when dragging it (using the move tool) to put it beside another geometry, the osnap does’nt work anymore, and I get not option to place it where i want to.
Note that I uninstalled the program and installed it again, but the problem still the same.
Thank you!!
use gumball and change it’s setting to snappy dragging
Yes I did it, but didn’t work !
Have you ticked the box for “osnap” and the option where you want it to snap?
