Snap fails on some objects affected by Clipping Plane
I’d like to report an issue with object snaps and Clipping Planes.
When a Clipping Plane is active, snapping stops working on some of the objects affected by it — seemingly at random. Other objects in the same scene snap normally.
I’ve tried turning the affected objects off and on via the layer panel, and disabling/re-enabling Osnap, but the issue persists.
I’m attaching a short screen recording that shows the behavior.
Setup:
  • Rhino 9 WIP
  • macOS
Thanks
Hi Tiziano -
From your video, it seems limited to that one object in the scene.
Please post a 3dm file in which you can reproduce the issue.
I’m sorry, but I can’t share that file. I’m also no longer able to replicate the issue easily. However, I’ve noticed it tends to come up again when changing CPlanes (on an object surface) and then trying to do Osnap on it — it randomly stops working.
