The ChangeLayer command causes the WIP to crash for me when I select the layer to change the object to. This does not happen when I use the Change Objects to Layer fuction in the layers panel. This happens when I invoke the command CL using instant aliases and accidentally press space to activate the command. This happens in an empty file with just one rectangle drawn.
Steps to reproduce
Open a new file
Create a rectangle in the default layer
Make sure to enable Instant Aliases for CL: ! _ChangeLayer
Type CL followed by a Space (as if instant aliases was not enabled)
Notice how Rhino crashes
This is in 9.0.24345.12305, 2024-12-10, Windows 10.
Hi -
When you crash, and then start Rhino again, create a rectangle and run cl + Space, does that crash again?
I just installed (9.0.24351.305, 2024-12-16), launched Rhino, pasted an image from the clipboard, and hit cl + Space. That crashed. I have since tried that several times again but am not getting more crashes. The Space just makes the Layer for objects disappear before being able to select a different layer. But that is expected, since the Space equals the OK button in that dialog.
EDIT: OK, this is rather reproducible… I’ll write it up.
→ RH-85206 Aliases: Instant ChangeLayer Crashes Rhino
