I how I can change the default display option in perspective view when opening a new rhino file. Can I export this setting and then imported in an other computer if I wish to?
Thank you in advance
I don’t think that is possible because of how Rhino’s default displays are hard coded.
What is the problem you’re trying to solve?
Hi Theo - the display mode for a viewport is a file setting - you can set your own template files to have certain display modes for new files, for example, but it will not affect other files are not saved the same way. On the other hand, the specific settings for display modes are not carried in the file but depend on what modes you have set in your Rhino - so Shaded may look completely different on your machine compared to mine, depending upon our settings…
