Default Display Mode
How do I change the default display mode to Shaded so every time Rhino is opened it is set at Shaded instead of Wireframe? I am using Lunchbox in Grasshopper to save .3dm files and I need them to be saved as shaded to be used in another program.
This info is stored in your templates. Open your favorite Rhino template(s), set all views to ‘Shaded’ then use “Save as template” and overwrite the original… Next time you open a new file based on that template, the views will all be in shaded.
HTH, --Mitch
