ChamferSrf request link distance option
Hi All,
Today after a long time I used ChamferSrf in WIP 9, and the panel looks similar to the new Filletsrf. At first sight this is a good thing, but what looks strange to me is that there is no way to link the distances. Shouldn’t we have this option and just a single range option?
I think you might want 3 options?
1 Single distance
2 Two distances that are linked (so fixing the ratio)
3 Two distances that free (current)
Well, isn’t your point 1 (single distance) the same as point 2 when two distances are linked and you star with equal values?
Point 3 is what happens without linking them.
I would add a little option to reset the distances values , I’m not sure if it makes sense, but the current menu seems a little repetitive and not that easy to use to maintain the proportion of the chamfer.
not from a UI point of view, I think.
in mode 1 only one slider is enabled, and you don’t have to bother resetting slider 2
RH-94237 ChamferSrf: different UI modes
RH-94237 is fixed in Rhino WIP
