Same situation with Rhino8 for Mac. Can’t close Rhino or dublicate the file. “Revert Changes” button just not working, Rhino will try to connect with folder where it can’t get accsess. “Dublicate file” also will try to access folder it can’t get access any more. You must close Rhino in this situation with “end proccess” whitout saving. Also you can copy all ojects, paste to new file, save this and kill the Rhino proccess.
There are changes in cases if “Save” or “Move To…” will not work. Now “Revert Changes” button works on Rhino 8 for Mac.
If you can’t close or save your work: you can make visible all layers, View → Zoom → Zoom Extents, now select all your objects, File → Export Selected … , and export your stuff where you want, then you can close Rhino (use “Revert Changes”).
