Can't reference geometry in Hops in Rhino Inside Revit
I built a Hops definition that work in normal Rhino. However, it doesn’t work in the grasshopper of Rhino Inside Revit. Any idea why or how to fix it?
Hi Talfrd,
Please run systeminfo in Rhino 8 standalone, then in Rhino.Inside.Revit and post the results. I suspect you may be running in different .net versions.
Hi Japhy, I run Rhino 7. The file works fine in standalone Rhino but not in Rhino Inside Revit.
Here are the two systeminfo texts:
---------------------------------In Rhino Inside Grasshopper:
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-2-2023
Driver Version: 31.0.15.3779
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.1.0
C:\Program Files\Rhino 6\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino6.rhp “Karamba3DLicense”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
----------------In Rhino 7:
icense type: Commercial, build 2023-12-12
License details: Cloud Zoo
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Hi Talfrd,
Not seeing anything wrong with a simple example.
Lets try isolating from 3rd party influences.
You can disable 3rd party plugins in File>Properties>Plugins
