Hi All,
I am looking for help with Rhino Inside Revit, it is currently causing Revit 2024.3 & Revit 2025.3 to crash with the below error message.
I have Rhino 7 (7.36.23346.16351) & Rhino 8 (8.15.25013.13001) and Rhino Inside 1.27.9121.7152 installed.
I have 2 scenarios where Revit crashes when trying to open grasshopper from Rhino Inside.
Scenario 1: Revit 2024.3 using Rhino 7 in Revit Inside - Revit crashes with above error when opening grasshopper from the ribbon or from Rhino window.
Scenario 2: Revit 2025.3 using Rhino 8 in Revit Inside - Revit crashes with above error when opening grasshopper from the ribbon but grasshopper loads if I open grasshopper from with Rhino window.
In both cases Rhino opens up from Rhino Inside tab.
I have tried the following things so far:
- Unloaded 3rd party plugins from Revit, I tried using Rhino Inside today after 6 months, it was working properly last time I used it.
- Read the Revit Journal file to identify an issue, extract from journal below.
' [Jrn.ExternalEventExecution] Rvt.Attr.AddInId: 02eff7f0-4921-4fd3-91f6-a87b6ba9bf74 Rvt.Attr.AddInName: Rhino.Inside Rvt.Attr.AddInVersion: 1.27.9121.7152 Rvt.Attr.ExternalEventName: ShowEditorAsync Rvt.Attr.VendorDescription: https://www.rhino3d.com/inside/revit/1.0/ Rvt.Attr.VendorId: com.mcneel
' 0:< ::100:: Delta VM: Avail -3 -> 134085796 MB, Used +2 -> 1665 MB, Peak +16 -> 1683 MB; RAM: Avail -28 -> 11203 MB, Used +7 -> 1847 MB, Peak +23 -> 1866 MB
' 0:< GUI Resource Usage GDI: Avail 8166, Used 1834, User: Used 1381
' 0:< ANTECEDENT:
'editor ArrowEditor
' 0:< Exception occurred
'C 16-Jan-2025 15:26:21.146; 0:< ExceptionCode=0xe0434352 ExceptionFlags=0x00000001 ExceptionAddress=00007FFA196CB699
'C 16-Jan-2025 15:26:21.146; BC: 0,3,1
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 11204 / 32452 1847=InUse 1866=Peak
' 0:< VM Statistics: 134085799 / 134217727 1665=InUse 1683=Peak
' 1:< ::100:: Delta VM: Avail +5 -> 134085801 MB, Used -1 -> 1664 MB; RAM: Avail +288 -> 11491 MB, Used 1847 MB
' 1:< GUI Resource Usage GDI: Avail 8166, Used 1834, User: Used 1376
'C 16-Jan-2025 15:26:23.980; Revit worker 1 closed cleanly
'C 16-Jan-2025 15:26:23.982; [0000423c]QueueMinder stopped
'C 16-Jan-2025 15:26:23.982; 1:< logging finished virtualization services
'C 16-Jan-2025 15:26:23.982; 1:< logging finished worker services
'C 16-Jan-2025 15:26:23.983; 1:< logging erased queues
' 2.830874 1:<<<Terminating RevitWorker Processes
' 0:< ::100:: Delta VM: Avail +114 -> 134085915 MB, Used -81 -> 1584 MB; RAM: Avail +320 -> 11812 MB, Used -79 -> 1768 MB
' 0:< GUI Resource Usage GDI: Avail 8162, Used 1838, User: Used 1348
' 0:< CefSharp has been shutdown successfully!
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files.
'Select Help or press F1 for more information on possible causes of unrecoverable errors."
' 0:< MFC MainFrame activated
'C 16-Jan-2025 15:26:24.885; 0:< Notify Active View.
'H 16-Jan-2025 15:26:24.886; 0:<
Jrn.Data _
"MessageBox" , "IDOK" , "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files." & vbLf & "" & vbLf & "Select Help or press F1 for more information on possible causes of unrecoverable errors."
'C 16-Jan-2025 15:26:24.886; 0:< License shutdown starting
'C 16-Jan-2025 15:26:24.920; 0:< License cleanup complete: 20, 0
'C 16-Jan-2025 15:26:24.920; program terminated
I would really appreciate if anyone is able to help with this.
Thank you.
