I can open Rhino Inside Revit but when I try to open Grasshopper I get a fatal error and everything shuts down (Revit included). I’ve tried uninstalling and re-installing both Rhino and Rhino Inside.
The log file on my desktop contains the following:
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.FileNotFoundException: Could not find file 'Grasshopper.resources'.
at System.Reflection.RuntimeAssembly.InternalGetSatelliteAssembly(String name, CultureInfo culture, Version version, Boolean throwOnFileNotFound, StackCrawlMark& stackMark)
at System.Resources.ManifestBasedResourceGroveler.GetSatelliteAssembly(CultureInfo lookForCulture, StackCrawlMark& stackMark)
at System.Resources.ManifestBasedResourceGroveler.GrovelForResourceSet(CultureInfo culture, Dictionary`2 localResourceSets, Boolean tryParents, Boolean createIfNotExists, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo requestedCulture, Boolean createIfNotExists, Boolean tryParents, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture, Boolean wrapUnmanagedMemStream)
at Grasshopper.My.Resources.Res_CanvasToolbar.get_OpenFile_24x24()
at Grasshopper.GUI.GH_DocumentEditor.InitializeComponent()
at Grasshopper.GUI.GH_DocumentEditor..ctor()
at Grasshopper.Plugin.Commands.ShowGrasshopperEditor(Boolean showUponLoad, Boolean repairPosition)
at RhinoInside.Revit.GH.Guest.ShowEditor()
at RhinoInside.Revit.GH.Guest.<ShowEditorAsync>d__12.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
Version info:
Rhino.Inside Revit: 0.0.7622.9729 (13/11/2020 5:24:18 AM)
Rhino: 7.0.20314.03001 (Rhino 7)
Revit: 2021.2 (21.1.10.26)
