I can find ExplicitHistory in the new build.
Try “Grassshopper”
and read the release notes:
Huh, ExplicitHistory
should have also worked. Odd. Regardless, Grasshopper
should work.
UPDATE: ExplicitHistory
still runs, it just doesn’t autocomplete.
Yep, works under Grasshopper.
And under ExplicitHistory
…the command just does not autocomplete, but it does work if you type ExplicitHistory
and press enter Forget the old command…the new one is better
Just don’t try it with 3 "s"s …it might not work
Goood catch
in my Case no explicithistory, no Grasshopper and no Grassshopper works…
“Unknown Command”
after a restart of Rhino everything still runs! - strange…
Yeah, that’s pretty strange. No idea what is causing that.
