Can't draw in frontview
I want to draw a line from the front view, but I can only draw it from the top view
You might have accidentially activated the “Planar” tool in the status-line at the bottom of your screen? Try to disable it
Hi -
When you get the “No Parking” sign, that means that the mouse pointer isn’t falling on a CPlane in that view. It’s impossible to tell from that picture, but you might want to consider making sure that the CPlane grid shows (and is big enough) in your display mode.
If all else fails, running the 4View command twice will reset all viewports to the defaults and will ensure that the CPlane in all views is accessible.
