Following on from this post:
Hi, I’m not sure if this is the same issue, but I am unable to open the Python Editor. When I select
Command: _EditPythonScript
I receive the message:
Error occured loading plug-in
Details:
Failed to load language 'IronPython 2.7.5': Method not found: 'Boolean Microsoft.Scripting.Utils.ReflectionUtils.IsInterface(System.Type)'.Unknown command: _EditPythonScript
Version: Rhino 6 SR0 2017-6-6 (Rhino WIP, 6.0.17157.8191
I get the same error:
Details:
I do have another version of IronPython installed but I need this to use numpy in the 32 bit Rhino 5. Uninstalling this is not really an option.
Does anyone have an alternative work around?
dale
(Dale Fugier)
April 12, 2018, 9:42pm
2
Hi @wattzie ,
Do you have IronPython installed? Check Control Panel > Programs and Features.
– Dale
Yes I do but I need this to use numpy in the 32 bit Rhino 5. Uninstalling this is not really an option.
I also get the same error when starting Grasshopper:
Priority: GhpyLoader
TargetInvocationException
Just to be clear, this is happening with Version 6
(6.3.18090.471, 2018-03-31)
Wattzie is right, we still need a way to use Numpy and SciPy in Rhino 6!
Importing Math.NET as suggested in the following post is far from giving you the power and flexibility of Numpy and SciPy…
stevebaer
(Steve Baer)
April 13, 2018, 3:03pm
6
What version of IronPython is installed when you go to the control panel? I would like to try and repeat this.
As a replacement for the aging 32bits version of SciPy and NumPy that were host by Enthought here:
http://code.enthought.com/.iron/README.txt
http://code.enthought.com/.iron/eggs/index.html
a tech support from Enthought suggested that I use the following Pythonnet package (which seems very much alive compared to the IronPython on which Microsoft stopped working in 2012):
Does anybody have tried it with Rhino 6 (64bits)? Could it be a way to use up to date powerful Python libraries within Rhino?
nympy and scipy were installed following the procedure in this thread:
Once I log into the my Enthought account, I see the page you are talking about. I have successfully installed IronPython (step 1) and made it available by adding the installation path to the my user PATH environment variable (step 2).
I also downloaded the file ironpkg-1.0.0.py in a tmp directory and run the installation command:
C:\temp>ipy ironpkg-1.0.0.py --install
Bootstrapping: c:\users\bmartin\appdata\local\temp\tmpnkqsba\ironpkg-1.0.0-1.egg
118 KB [........................…
It is a little convoluted but it works and gives access to the entire nympy scipy library that I have found invaluable in my development.
PM me if you are having trouble with this installation and i can send you a more detailed procedure.
piac
(Giulio Piacentino)
April 13, 2018, 4:31pm
10
wattzie:
2.7.1
Have a look at this:
Over the last few months, we received several reports about issues with independent IronPython installations (IIPI) and Rhino. IIPI are only installations of IronPython made via MSI files, and they appear in the Control Panel like this:
[image]
It is possible to install IronPython via folder decompression, and that has no impact on Rhino.
I installed both IronPython 2.7.5 and IronPython 2.7.7 final from the IronPython website and checked for compatibility with running the _EditPythonScript e…
You should get away by disabling the GAC option in the installer.
Interesting, Thanks! I will try it early next week and update on the results.
Uninstalling 2.7.1 and installing 2.7.5 does the trick.
Thanks!
