I downloaded Rhino for Windows, rh50_en-us_5.12.50810.13095.exe, and whenever I run it on a Windows 10 Pro x64 platform, the install fails.
Here’s the log file:
uid=3281c150-1bdc-4f30-9e39-8f656e102e76
datetime=2015-12-30T11:42:09-08:00
rma-msi-version=5.12.50810.13095
Installation Starting
GetInstalledRhinoDetails returning false; Registry key not found
2015-12-30T11:42:28-08:00
Executing Child Installers
Installing dependency 'UNINSTALL_MSI' from '{E501C2B8-94A7-4254-B420-97158A594A82}' with status text 'Uninstalling 32-bit Rhino 5 Beta'
Installing dependency 'UNINSTALL_MSI' from '{72C91ACB-6D63-44F6-B8B2-26C78F33F9C8}' with status text 'Uninstalling 32-bit Rhino 5 Evaluation'
Installing dependency 'UNINSTALL_MSI' from '{301D9C4D-E327-4D6C-BA7D-6E55A6FE3E54}' with status text 'Uninstalling 64-bit Rhino 5 Beta'
Installing dependency 'UNINSTALL_MSI' from '{D5F28B29-AFB8-4FA7-9E83-56D2751527A4}' with status text 'Uninstalling 64-bit Rhino 5 Evaluation'
Installing dependency 'MSIEXEC40' from '../Installers/Prerequisites/WindowsXP-KB942288-v3-x86.exe' with status text 'Installing Windows Installer 4.0'
Windows Installer version 5.0.10240.16386 detected; no installation required
Installing dependency 'DOTNET4FULL' from '../Installers/Prerequisites/dotNetFx40_Full_x86_x64.exe' with status text 'Installing Microsoft .NET Framework 4.0'
Starting and waiting for process msiexec.exe /i "c:\users\admini~1\appdata\local\temp\7zs81b4.tmp\installers\rhino5setup_en-us_x86.msi" /qn RMA_LICENSENODETYPE=Evaluation INSTALL_EN=1 USERNAME="Rachel Mast" COMPANYNAME="" /l*+ "C:\Users\ADMINI~1\AppData\Local\Temp\mcneel install (2015-12-30 11-42).log"
Process completed with exit code 1603
Installation failed; exit code 1603
The support site says a few things that make no sense. First, it suggests that I run the Dot Net 4.0 Framework directly from the DVD. There is no DVD. This was a downloaded install. Then it provides a link to Microsoft’s site to download and install the Dot Net 4.0 Framework. When I do this, the downloaded Dot Net 4.0 Framework install program stops and reports that there is no need to install the framework; that Windows 10 already contains the Dot Net 4.0 Framework.
So I have been unable to install Rhino 5 on Windows 10.
Any suggestions?
