Hi, I downloaded Rhino7 for Windows, “rhino_en-us_7.1.20343.09491.exe” and I run it on a Windows 10 Home Edition.
But nothing happened. I think the installer keeps crashing after opening.
my Windows10 Home is current version.
I can use Rhino6 on the Same machine.
The installer could run on another PC(windows10 pro x64).
Thanks @John_Brock
But I had run the installer, after stopped an anti-virus software.
And my another PC which is running on win10 pro and the same anti-virus app can run the installer.
Seems no one found a solution i am currently having this problem as well i had rhino 6 installed and it runs but the installer for rhino 7 crashes the moment i click install.
No i was not using any antivirus software i had tried 2 different installers but all of them had the same issue, though the solution was to simply run in administrator mode, so the issue is solved for me for now. I hope you guys can figure out the issues with the installers since they seem to be causing unnecesary problems for an otherwise extremely usefull program.
