So I guess CAD imports neglect to include Multi Leaders? I swear I never had this problem before.
rhino leader test.dwg (67.3 KB)
Hello- Rhino does not have an equivalent object that I know of - I suppose it is just converting to text since it canāt decide on which leader to use.
Iām going to try and see if dimension leaders convert (since Rhino leaders are embedded in an annotation style I think?). The leaders in my DWG are multi-leaders.
Iām also going to see if they import into layouts.
This kind of sucks because it wrecks my intended workflow.
Everything in the program seems so close to perfect but you reach a hiccup right at the very end. It otherwise works so well with cad.
Hi Keith,
Thanks. We can see that.
We have logged:
RH-71782 AutoCAD Multileader without Text Do not Import to Rhino
Sincerely,
Mary Ann Fugier
McNeel Technical Support
Thanks!!
For the record I think itās only worth fixing if itās an easy fix. Iām already contemplating a couple different directions to circumnavigate the issue, which I anticipate will take me half of a Saturday.
Hi Keith,
Issues in your file Leader test 2.DWG were logged as 2 issues from :
RH-71782 - AutoCAD MultiLeaders with No Text Do not Import to Rhino
RH-71783 - Leader with User Arrow Needs Arrow Block Assigned
Some of the issues in your file Leader test 3 DWG were related to :
RH-71782 - AutoCAD MultiLeaders without Text Do not Import to Rhino.
There are leaders in AutoCAD with the leader deleted and a frame around the text.
As a workaround, you can Explode the Leader into text and the curve around it.
Then it will import to Rhino properly.
Other leaders were having an issue with the AutoCAD Annotation scale setting, And I need to adjust a couple styles to prompt for mtext because of RH-71782.
These leaders were set to use the AutoCAD Annotation scale. Rhino does not currently support this. So as a workaround, you need to turn this off.
You can turn it off in the Leader style.
I found I had already been logged as a bug 6 years ago. ![]()
But sadly no love here for this bug.
RH-36210 Rhino Not Opening DWG/DXFs with Annotation Scale On Correctly
So I rewrote the but as RH-71799 Annotation-Scale-not-Imported-to-Rhino and included some a clearer example files. Also since Rhino does not support Annotations scale exactly like AutoCAD, at import these will be reset to Model scale, which is a setting that both AutoCAD and Rhino support. They will also import back to AutoCAD as Model scale.
In the mean time, you will need to embrace the workaround suggested or fix the scales once they are in Rhino. Of course, I know that you need the RH-71782 (AutoCAD MultiLeaders with No Text Do not Import to Rhino) to be fixed. You will be notified here when there is a fix in the WIP for you to test.
Hope this helps.
Sincerely,
Mary Ann Fugier
leader 3 no anno scale.dwg (46.5 KB)
Hi Keith,
I would like to understand this better:
What are the specific features for documenting in AutoCAD that Rhino does not have or you prefer to use in AutoCAD?
If Rhino does not have them, I want to verify that we have the feature request logged in the tracking system.
Thanks,
Mary Ann Fugier
Itās definitely helpful Mary!
Iām quite handy at creating scripts in AutoCAD. So many of the above work-arounds will be easy(ish) to implement. The key for me is knowing what I have to work with, and adjusting my standards accordingly from there. The little surprises are what halted my overall progress (temporarily).
Perhaps I could make a video at some point. It would be way easier to convey that way. But Iāll leave a brief explaination.
Dimensions (which are quite good in Rhino once you get used to them):
In AutoCAD, immediately after selecting the object you have access to all relevant grips. In Rhino, you need a couple clicks. In the example shown I would either have to zoom in, or select one of the grips off to the side to expose the textās grip. Note that his is very minor, the leader issue described below is far more important.
AutoCADās automatic dimension leaders suck. What I actually often do is just use leaders; I make sure the text is set to be able to just move manually.
Note that although the dimension is snapping to the āendpointā, it will snap to the dimension lineās āmidpointā. The red is my leader which Iāve added over top of the dimensions automatic leader.
I already have my ACAD style leader macroās programmed in Rhino, so I can just add my leaders automatically (and quickly). I canāt snap to the dimension lines however, so adding leaders right at the mid point is harder.
Maybe itās worth taking a consensus as to whether other users would prefer more āsnappingā on dimension objects; personally, I feel that if the dimensionās nodeās are snaps, the mid-point of that line should also be a snap.
Not a big issue, but moving leaders while the leader pointer stays stationary is a tad slower in Rhino, and may be un-intuitive for some if you have landings turned off. You have to shift-select all nodes in the boundary shown when the leader is selected:
This is probably most important: AutoCADās text editor is way more modern and feature rich.
GstarCADās editor (below) is hot on Autodeskās heels (along with BricsCADās and most other CADās):
Hi @keithscadservices,
This is helpful.
I made this terribly quick video on editing dimension with control pts.
Again I made a quick video with how to dimension to the mid pt of a leader.
Stretch in Rhino is really best described as the moving some control points on an object, and leaving others behind.
When you pick on a curve or annotation, the points turn on and you can select the ones you want to move. You will see that in the video too.
I donāt know what a lot of these icons mean, but here is a start on the list:
Rhino already has:
I logged a YT for these enhancement to Text: RH-71945 Enhancements to Text:
I know there is a lot there. But if we can focus on the biggest pain points, then we can carve into the other items in a the next round.
Let me know if you agree with my list of priority enhancements to Text.
Sincerely,
Mary Ann Fugier
Hi Mary. Great video! I learnt a few things.
Iāve found another issue thatās a bit harder to work around: Leaders seem to be importing onto the ādefaultā layer regardless of what layer I have them on in ACAD.
This would be harder to fix because I donāt have the Rhino scripting skills that I have in ACAD. Iāve already found a few tricks to sort out much of the other stuff.
Hi Keith,
Good to hear the videos were helpful.
I tried it with one of mine own DWG, (attached) and the exact layer I am using in AutoCAD, is the layer that Rhino imports.
Please send a small test file that will show me the issue.
Thanks,
Mary Ann Fugier
anno text dim leaderS 02.dwg (39.2 KB)
No file needed as even your file has the same behavior. I checked so many things :-S (various things in the leader style, fresh drawing, layer already existing, etcā¦). The layer itās on will import.
I suppose I could run a script after importing: āIfā my leader is a certain style put it on the layer I want.
For now I have to give the AutoCAD ā Rhino thing a rest. I may have mentioned Iām working on what is just a basic template and trying to do so in a way that imports nicely into Rhino.
I still plan to make a video: Just the differences between ACAD and Rhino and why I gravitate towards ACADās annotations.
Hi Keith,
To continue investigating this issue, I need 1 leader in a DWG and I need the DXF of the same leader that you generate from your AutoCAD.
These files will hopefully tell me where you need to look for the culprit.
Thanks,
Mary Fugier
Iāve also tried GstarCAD 2020 with the same result. Maybe Iām missing a setting within Rhino itself? Strange that only the leaders are affected.
# RhinoTest 014.dwg (111.0 KB)
# RhinoTest 014.dxf (680.6 KB)
Edit: Note that Iāve placed two leaders in the bottom right (with text so they actually show up) - those are the only things weāre currently looking at. I think for now Iām going to wait until Rhino 8 until I try to create a template that imports correctly. For now Iām just getting my AutoCAD templateās ducks in a row.
Hi Keith,
Thank you for the files.
I was able to duplicate the issue and I logged RH-72048.
I will let you know when I see a fix.
All bugs fixes are applied to the current development version which is Rhino 8 WIP.
So you will be able to test the fix there when it is available.
Sincerely,
Mary Ann Fugier
The hardest part sometimes is āduplicatingā the issue. Thanks again for your help on this!!
Was there any progress on this? For years Rhino 7 (and previous versions, I canāt say exactly when) has been importing AutoCAD leaders onto the current layer. This is always unwelcome at best.
I would actually be able to create an AutoLISP script that would export all the leaders⦠letās say in CSV format (or whatever) and include layer information. Then I could open Rhino and run a C# script to import that data. This would be easy enough in 2D. For 3D and multiple planes I have next to no experience.
The thing is that if I can do itā¦
Hi @anon ,
This was fixed in Rhino 8 on 3 Jan 2023.
It should have been announced here. But I do not see it.
Rhino 7 users are welcome to download and test the fix in the Rhino 8 Beta here.
Let us know if it works for you.
Thanks,
Mary Ann Fugier
Itās nice to hear but I think many of us really wish these things were fixed in R7. If something is broken, and doesnāt take a monumental effort to fix⦠it should be fixed. I see how much resources they are dumping into Rhino in Revit among other things. Importing a CAD file isnāt anything groundbreaking. But I suppose if the issue only affects a small portion of customersā¦
Many people wonāt be able to upgrade to R8 (due to hardware issues). I might stay at R7 for up to a year just to avoid having to upgrade. Iāve kind of made other arrangements to work around the lack of being able to import DWGās effectively. Itās kind of a shame because most of the stuff imports really well. It almost wastes all that effort by not polishing off the final details.
