I have a bug with texture and roof windows
bug roof window.3dm (1.9 MB)
This is due to coincident faces of different geometry. You also have duplicates in the same place. Clean that up and you’ll get rid of this issue.
Looking “inside” your roofing:
Clean up the geometry in your block and you should be fine.
*Dalle{6b074add-2788-4292-82bd-b0099446c854}_BlockEdit_BlockEditHi @nathanletwory thanks its works but when i move the window again the bug reappear so i must do manipulation with _blockedit again.
For further VA issues I’ll have to let the VA people answer. @fsalla, something you can help with?
Hi @Henry_Boutet_de_Monv we will revise how this roof is generated when inserting a window. It looks like the roof layers are not cut correctly when a window is inserted.
@Henry_Boutet_de_Monv This issue has been fixed in VisualARQ 3.11 RC1: VisualARQ 3 - Version 3.11 RC1 released
