Roof intersections
Keep running into the same issue project after project where i cant control the way roofs intersect without manually creating them from surfaces ( but when you create from surfaces, you lose maneuverability). The issue happens when roofs align - in any way pretty much. example:
House with existing roof needs an extension:
The loer roof represents the extension and the stippled lines show the way i want the roof to extend.
I then extend:
And then this happens:
Why?
I attached the file but its very easy to recreate,
Roof_example.3dm (198.0 KB)
Hi @Jens_Jacob_Melhus_J1 This is a bug. I could reproduce it with your file. I’ll let you know when we fix it.
Strangely, if I create to new gable roofs, the first roof doesn’t “breaks”:
Gable roofs
Hi @Jens_Jacob_Melhus_J1 I let you know that this issue has been fixed in VisualARQ 3.8 RC1 version, available here: VisualARQ 3 - Version 3.8 RC1 released
