BUG - section tool V8 (wip9)
It may be already adresses elsewere but I’m still fighting whit tech drawing for product design:
Today issue is about hidden lines showed throu the section.
V8 not only hide hatches if there’s the solid option On but also shows hidden line even if the ShowSolid is ON:
And this the V9 that’s going better but still has issue with internal Tangent curves.:
@rajaa I know: I’m always bother at you.
Is this smtg that could be adressed for V8 as well?
Thanks
20250304_ModelMania2020.3dm (3.9 MB)
Hi Riccardo -
When I copy - paste the object into a new Rhino 8 file and create new drawings, I’m not seeing those issues. Running (8.29.26033.22001, 2026-02-02).
I’ve put this issue on the list as RH-92065 ClippingDrawings: Unwanted Tangents
Thanks Wim,
I’ll wait for the update (probably today) to check it.
@wim,@rajaa, @Nikolay I’m here again because the problem is still happening to me and I think it may be related to V-Ray.
I’ve V-Ray installed on the system and when I open the file I get a ClippingPlane conflict alert:
My System Info V8
Rhino 8 SR29 2026-2-10 (Rhino 8, 8.29.26041.10001, Git hash:master @ 6f4761d87df45e886dd6b32508dff6a4c7e45f29)
License type: Commercial, build 2026-02-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.19
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 4-18-2023 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.88
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-13-2024
Driver Version: 31.0.15.5188
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.15.0.276
C:\Users\gttrc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26041.10001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Thanks
The partial solution is putting the view in shaded mode:
maybe the “solid Surface” on clipping drawings could be set as shaded by default?
But then the print must be raster loosing in quality.
Hi Riccardo -
Multiple things were reported in this thread, so you’ll need to be specific on this.
RH-92065 is still open…
The way to check that is to disable the plug-in, restart Rhino, and then check if the behavior has changed.
Personally, I don’t understand the reason to include a surface in the output. As you say, to be able to do anything sensible with that output, you’ll need to print to raster. Isn’t the whole point of creating 2D section geometry, to be able to print to vector?
You can always set the background color of the section hatch in the section style to some color if you need a fill behind the hatch pattern.
