BUG? - RhinoCode CLI
Hi @eirannejad
I’m experimenting with the RhinoCode CLI on Mac, and I really appreciate this tool. However, I’m experiencing some unexpected behavior when passing commands. For instance, this line:
rhinocode --rhino rhinocode_remotepipe_20080 command "-SetDocumentUserText arg test"
does not work. It seems like the first argument gets passed twice, so the result ends up being:
Command: -SetDocumentUserText
Document text key-SetDocumentUserText
Document textargs
Command: test
Unknown command: test
I’ve experienced similar behavior when passing “-GrasshopperPlayer somePath”.
Am I doing something wrong, or is this a bug?
R8.17 Mac
Best,
Johan
Hmm this seems to be a bug. The key:value does not get parsed correctly. The cli is passing the args directly to Rhino so I don’t really know what is happening there. Let me take a look and I’ll put a fix for this
RH-86650 RhinoCode CLI does not run command correctly
Hi @eirannejad
Thank you for getting back to me—I really appreciate it.
Best,
Johan
Anytime. I put a fix for this for 8.19 SRC. I can send you a test build tomorrow if you want one
Wow, that was fast! :slightly_smiling_face: I’d love a test build—thanks!
RH-86650 is fixed in Rhino 8 Service Release 19 Release Candidate
