Tom_P
December 18, 2023, 10:41pm
1
sorry if I write 2 Bugs in one topic
(1) Rhino window disappears
steps to reproduce
open new document.
hover over nested toolbar.
while focus is on this toolbar type some stuff (“box”, “boundingbox” …)
now slowly move the mouse back to the commandline - as soon as mouse is over input-field - rhino window is lost.
EDIT:
(2) commandline - flyout / suggestions /
moved to new topic
.. . mouse click on highlighted command is different then on other commands in the list:
in the example I double-click on extrudeCrv and still have to press enter until the command starts.
but for extrudeSrf just a single click is enough (this should be the behaviour for both scenarios)
.. .the flyout window should stay left aligned and fixed position… see the flickering while I browse the list with the cursor.
… long commands are of the monitor - see me …
thanks for haveing a look at those things - kind regards - tom
pascal
(Pascal Golay)
December 18, 2023, 11:38pm
2
Hi Tom, thanks, I’ll check this.
@Tom_P - something must be different, here - if the cascaded toolbar has focus, I just get beeps from typing.
Tom_P
December 19, 2023, 12:03am
3
yes i have the beeps also (did not manage to record system audio, sorry)… no input … and then move the mouse…window disappears…
Tom_P
December 19, 2023, 12:37am
4
but were you able to reproduce the disappearing window ?
pascal
(Pascal Golay)
December 19, 2023, 12:40am
5
Hi Tom - I was not so far, no. I gather it is reliable for you…?
Tom_P
December 19, 2023, 9:52am
6
(not sure if I 100% understand your question “gather+reliable”)
…yes I can reproduce this Bug without any problems (also after restart)
dan
(Dan)
December 19, 2023, 10:47pm
7
(It is very helpful to have these bugs in separate topics, but as they are reported in a single post, they are not easy to tease apart.)
The first bug
looks very similar to:
Please refer to this video.
It is a capture of the error where the screen disappears.
Error is also occurring in the latest version.
Rhino 8 (8.3.23346.14002, 2023-12-12)
Mac ventura 13.6.2
Apple M2 Pro
which I also cannot reproduce here. Not for lack of trying.
Tom_P
December 19, 2023, 11:06pm
9
Dan:
in separate topics
… sorry I got a bit lazy regarding bugs.
create a separate topic, as there where only reply s to the disappearing window…
hope that s fine now and get solved soon.
thanks.
dan
(Dan)
December 19, 2023, 11:38pm
10
No worries Best that the bugs get reported…just mentioning that it helps us juggle these if they are separate.
I will attempt to reproduce this on macOS Ventura and Monterey (because I’m having no luck in Sonoma)
Tom_P
December 19, 2023, 11:44pm
11
I am on Ventura 13.5.1 (22G90)
systeminfo_tp_23-12-19.txt (4.8 KB)
dan
(Dan)
December 20, 2023, 12:06am
12
I tested with Rhino 8.3 for Mac on macOS Ventura 13.6.1 and I could not reproduce this behavior. I cannot type once the nested toolbar is visible.
Tom_P
December 20, 2023, 12:20am
13
I also can not type - just get annoying “blubing blubing” beeps.
just type anything. a few characters
I think this is important to distract the focus
then slowly move the mousepointer ( i am using the trackpad of a macbook pro intel) -
EDIT - also can reproduce with external mouse.
dan
(Dan)
December 20, 2023, 12:28am
14
Success! At least partially. I can now reproduce this on macOS Ventura 13.6.1. Now I’ll try again on macOS Sonoma…
…and I cannot. This feels like a side-effect of a macOS bug that has been fixed.
