As the title says…
Look:
Thanks @Charles I see this too. This must be a very recent bug.
logged RH-73898 Rhino looses focus when dragging out a toolbar
The bug is different now.
The focus is lost on dragging out the first toolbar.
See:
Still the same!
pls send your systeminfo, as I can no longer reproduce this issue. I tried on both win 11 and win 10
Rhino 8 SR0 2023-7-24 (Rhino WIP, 8.0.23205.22305, Git hash:master @ fe37cd8cb1e286eda2f766cbbceee2cd98cb7817)
License type: Educational Lab License, Build 2023-07-24
License details: Stand-Alone
Expires on: 2023-09-07
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 4-25-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-25-2023
Driver Version: 31.0.15.3179
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\IntelDenoiser\0.6.7\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 1.0.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23205.22305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
It happens only for the FIRST toolbar to float.
Doesn’t happen if the is one more floating toolbars.
I tried to see if it had to do with localization, because I see no suspicious things in your info, but still cannot reproduce the issue you are seeing. I’ll ask if anyone else is seeing this here.
I thought it could have to do with the mouse auto positioning in the Windows settings:
I always use this setting.
But no, that’s not it.
The issue is still present in here.
hi Charles, I cannot reproduce the issue you are seeing anymore. This makes it hard to solve. @JohnM do you have a clue what could be causing this?
Strange.
I can repeat it very reliable in here.
Perhaps you can try once again to get the same effect?`
Hint:
The Notepad in the background had the focus before starting Rhino.
@Charles sorry, I still cannot reproduce that behavior here. Rhino stays in focus no matter what I try.
Strange.
I now have V8 beta on a PC with V5-7.
The WIP/beta was never installed before on that PC (Win10).
Same effect.
Means it’s not related to the Win11 machine for work.
@Charles Does losing focus happen if you have no other programs/apps such as Task Manager or Notepad open? I am just guessing about a reason that you see the problem and others do not.
I always have multiple windows open.
Now I tried with just Rhino and no other visible window.
Then the problem is not visible.
It’s not easy to be sure.
I did the test on Win10, and even in Dark Mode the Rhino titlebar is always white.
Having focus or not.
The Windows setting on this machine is titlebar color = blue.
All other apps respect the setting.
@Charles today I managed to reproduce this. Apparently there is a difference when cascading from the button or from the triangle.
RH-78099 Rhino 8 looses focus when dragging out a cascaded toolbar
Glad you could reproduce it.
I was not aware of the small difference.
Thank you
RH-78099 is fixed in Rhino 8 Service Release 3 Release Candidate
