This has to do with AutoDesk’s FBX SDK and there’s no work around. V6 uses a newer SDK than V5 and must produce V7 binary files that the older SDK cannot read. This was first discovered here. https://mcneel.myjetbrains.com/youtrack/issue/RH-37012
Hi JD - from what I can tell in these pictures, this looks more like a Blender bug or limitation?
Does the v7 binary format that you export from Rhino import correctly back into Rhino?
Sorry - I’m on 2.78. I did a test with 4 cubes and it definitely didn’t work with anything coming out of Rhino. If it just needs that new Service Release then I’ll try and get that installed ASAP.
