Bug Report: Mac Rhino 6 WIP Picture
The colour picker on the Picture / Transparency / Use Colour Mask seems to be broken.
Version 6 WIP (6.15.19078.12066, 2019-03-19)
Can post a video if you need, but seems to be easily replicable, I just open it up, put any sort of image in, and the bug is there.
Hello - thanks, I’ll check this.
Yep, I see this thanks. @John_Brock Run the color picker and the result when you’re done (here) is still black.
https://mcneel.myjetbrains.com/youtrack/issue/RH-51612
So far, I’m not seeing the problem.
My color picker in Transparency > Use color mask is working fine.
If you don’t mind, please post a screenshot or a video
I was wrong. The color picker did look like it went through the motions, but the color swatch in the panel did not change.
Screen recording here —
For me, nothing at all happens when I click on it as far as I can see
Buggified:
This should be fixed in the latest RhinoWIP. Thanks again for reporting it!
I’ve downloaded the update and am now seeing a new problem.
The colour picker appears, but the choice of colour mask doesn’t seem to affect transparency.
And the Tolerance is stuck at 0.0% and doesn’t seem to be editable.
@John_Brock Can you please try to reproduce this latest issue above? I admit I don’t understand how nor does the video load for me.
@tlukejones
Your videos are not getting uploaded.
Please describe the steps you were trying to show in the video so we can reproduce the problem here.
Thanks
Running the current WIP on a Macbook Pro 2016.
If I open a new file, key in ‘Picture’, select a jpg and place it, then select ‘use colour mask’
The colour picker works now but the mask doesn’t have any effect, and the tolerance setting is greyed out.
I see that.
Logged as: https://mcneel.myjetbrains.com/youtrack/issue/RH-51798
Thanks
You should now be able to set the Picture tolerance in the latest RhinoWIP.
