It’s been bothering me for quite a long now. Until now, I found this issue too obvious to bring up here, but it’s apparently not so much..
The setup is really quite simple :
- Create a block with a box inside
- Set the box color/print-color inside the block to “Parent”
- Put the block instance itself to another layer, or just set its color/print-color to Custom
- In default Technical display mode, try to Vector-print it. The box will desperately keep its original color.
In pictures :
Box color settings inside the block
Block color settings
Vector printing - we can see the background still displays the block as I set it up
To confirm the bug is related to vector printing, we can see that raster printing prints correctly
Hope this can be fixed
