[R8 Bug] Print Color of line in block follows Display Color instead
[R8 Bug] print color in block doesn’t follow Print Color. It follows Display Color instead
This bug breaks quite a lot of things because I have lots of lineworks nested in blocks and their Print Color cannot be set.
@stevebaer
@Wiley - Can you post a simple .3dm file that we can use to repeat?
Thanks,
– Dale
PRINTCOLOR_BUG.3dm (54.2 KB)
In the model, the Display Color of line is a turquois color, Print Color of Line in Block is Red
Paper Space: (If I use my Custom Display Mode where Display Color is turquois)
(If I use default Shaded Mode )
My Display Mode
M_Brown.ini (14.8 KB)
Hi -
Thanks → RH-84344 Print: Curve in Block Doesn’t Use Print Color
RH-84344 is fixed in Rhino 8 Service Release 14
