I think I’ve found a bug.
If I copy an object and hold down CTRL V it will eventually add an enlarged version of the copied object and will also add curves to document. Looking at the command line window it also looks like the command _PasteSVG was executed as well. The curves are far from the origin and look like a skewed wireframe of the selected object.
I’d expect the for the pasted object to have its original size and no extra curves added to the document.
My Specs
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Not For Resale Lab, build 2024-12-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET Framework 4.8.9277.0
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 6-28-2023 (M-D-Y).
External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Primary OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.2134
Integrated (slow!) graphics device with 3 adapter port(s)
Secondary graphics devices.
NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 3-23-2020 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
- This device is not being used
External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
The “Main Display” is conncected to an external USB display port device, which is preventing the
proper video drivers from being loaded by Windows.
Recommended:
- Use Windows’ Display Settings to configure the laptop screen as the “Main Display”.
- Or, unplug a monitor and plug it into a built-in video port (HDMI/DP) on the laptop.
Then use Windows’ Display Settings to configure that monitor to be the “Main Display”.
Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.2134
Driver Date: 11-20-2024
Driver Version: 31.0.101.2134
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
