SMC2
December 10, 2019, 1:20pm
1
Hello every one,
recently we have find a bug with dim in paper space.
if I make a drawing in the object space and if i add dim in a paper space ok. But if i make a new layaout and i copy past all object in the new layaout, then the dim value did not respect the scale factor of the detail view!!!
Add make a drawing and add dim in the firste layaout
creat a new layaout and copy past all object of the first layer in the new layaout.
do you see a problem with the dim values?
Best regards
wim
(Wim Dekeyser)
December 10, 2019, 1:40pm
2
Hi - Thanks! This was also reported here:
Yes, often copy and pasting between different layouts. Usually it is if I have to move whole details to other sheets after they are drawn and dimmed. As for attached / history enabled, it would be nice if it remembered what it was attached to, but I would very happily give up the dimension’s history for copy and pasting with its original length factor reserved.
Sam
Does this mean that this used to work differently in Rhino 6? If so, do you recall which version you were using previously?
SMC2
December 10, 2019, 1:53pm
3
Ho sorry i’m not view this topic.
on rhino 6 SR 19 there we have no problem
wim
(Wim Dekeyser)
December 10, 2019, 2:48pm
4
No worries!
Thanks! I rolled back to SR 19 and see that it worked correctly there. I’ll get this on the to-do list.
Reported as RH-56193 .
SMC2
December 10, 2019, 4:26pm
5
Ok great thank you very much
regards
brian
(Brian Gillespie)
January 29, 2020, 12:18am
6
RH-56193 is fixed in the latest Service Release
