Bug on linear dimensions
Hi!…
well I am pretty sure this is a bug.. what happens is that dimension changes the position of the measured points when I change the linear resolution.. it happend only to this dimension line.. but it is really odd that this happens (i have repeated the dimensions and that one always change).
I am attaching both Rhino and a video..
XPOSICION CONCLUSIONES.3dm (288.3 KB)
Rhino 8 SR26 2025-11-11 (Rhino 8, 8.26.25315.15341, Git hash:master @ 4b42a55825990477ad4b7cc41386e94f427bca4d)
License type: Educational, build 2025-11-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.14
Primary display: AMD Radeon™ 780M (AMD) Memory: 1GB, Driver date: 6-27-2023 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\mutar\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\25.3.0.0\bella_rhino.rhp “Bella” 25.3.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.26.25315.15341
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.26.25315.15341
Hi mutarq,
Can you repeat in a blank file?
Another thing to try is to open Rhino in Safe Mode (via windows start) which disables 3rd party plugins
hi!..
If I run in Safe mode.. it happens again (so no plugin is to blame I guess)
It is worth mentioning that it happens just with that dimension. I mean.. if i redraw the dimension. it may not repeat the mistake. And while that is the practical answer would be to redraw.. I would be very disappointed to find this bug again somewhere in the future..
thank you for looking at this.
Hi mutarq -
Without finding a way to reproduce that behavior, this is not something that can be fixed.
