V7 Layout/dimension(?) issue
Hi All,
Faced such unpleasant behavior many times.
Eventually made a sample file with the problem.
Could anybody confirm they have the same jumping of the dimension?
P.S. System info included.
222.3dm (253.3 KB)
Animation
SysInfo
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.2115
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 5-24-2023 (M-D-Y).
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
  • Recommended: Unplug the monitor and plug it into one of the video ports on this device:
    [NVIDIA Quadro RTX 5000]
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.2115
Driver Date: 11-16-2022
Driver Version: 31.0.101.2115
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 6\Plug-ins\DATAKIT\Rhino6_Import_x64.rhp “Datakit_to_rhino6”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Andrey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Iris\0.7.1\Iris.V7.rhp “Iris” 1.0.0.0
C:\Users\Andrey\VAI Group\PowerflowTorontoSharedDrive - Documents\MAIN DATA\Powerflow\Ken\Rhino\Scrips and plugins\V6\LayerRenameTools.rhp “Rhino.NET SDK” 0.0.0.0
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Users\Andrey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
Hi -
Thanks, I can reproduce that here
→ RH-78926 History: Deactivating detail makes dimensions jump
Hello, @wim .
Happy New Year!
I saw this issue was named as “fixed” on the latest RCs.
But I still can see some weird things here. Please, see attached animation.
In some cases dimension goes to the “virtual” circle, not to the actual edge.
And it still jumps in that case after switching to/from Detail view.
Animation
@Screamer as you can read in that YT, the remaining behavior is based on how curves are handled in views that are not parallel to the drawing, and cannot be avoided in the way it is currently implemented.
Hi @Gijs ,
Yes, I saw it.
Well, at least it “jumps” only once and then keeps it’s position.
This is way better, than before. :+1:
Thanks.
