When using the Linear Dimension command I get a rectangle (no gaps, no arrows and no dimension).
When I open a new model the issue is resolved. I have checked all the settings etc but being a new user I’m probably missing something obvious. Please help
This one is the page at Rhino Options > View > OpenGL.
Re-reading your first post - are you saying that it only happens in that one file - and consistently so. Or is the issue resolved when you close that one file and then reopen it? If the former, could you post the file?
Select that entity (what appears to be a rectangle), what does Rhino properties say it is?
My preliminary guess is that you’ve created a dimension, but your dimension text and arrows sizes are super small. Enlarge the model space scale of your current dimension style and see what happens.
