Rhino 7 SR10 2021-8-24
i select everything within range:
move it:
angular dimension is left behind partially:
Hi Ivan -
It’s hard to tell from the images but I was unable to reproduce leaving behind parts of an angular dimension.
schody_vyroba_final.3dm (6.5 MB)
Thanks for that file, Ivan.
I’ve put this on the list as RH-65502.
Are you able to reproduce this in a new file with just a few simple steps?
i dont remember how i did it but i suspect i used 3 points to define the angle and maybe there was some association to a point which was deleted afterwards and that could break something.
RH-65502 is fixed in Rhino 7 Service Release 11 Release Candidate
