[Bug] Editor frames do not scale in C# Script component!
Like Khaled used to blurt out… “another one”… :wink:
When trying to resize the C# Script component inside Grasshopper, the text frames - where you’re supposed to “edit code in” - don’t scale! The grey-ish padding just grows larger.
It doesn’t work, if I use maximise (green button top left) or a window arranging tool (e.g. Moom) either. I’m currently using :rhinoceros: 6 (6.27.20176.04592, 2020-06-24). If you’re curious about the specific file, where I noticed this, you can find it here.
Any ideas? Thanks.
Just for the boomers among us, who don’t know DJ Khaled. No offense! :rofl:
Hey @diff-arch,
Thanks again for reporting issues as you see them, it is really helpful!
I recently found this problem as well while working on this issue.
I’ve logged that bug as RH-59603.
Thank you, @curtisw! :slight_smile:
