Using _CPlane _Object on an oriented clipping plane leads to a Cplane that is no parallel to the oriented clipping plane, only centered on it, which is useless.
Steps to reproduce:
- open oriented clipping plane.3dm (33.7 KB)
- Use
_CPlane _Objecton it. - Result is unexpected:
Result should be a Cplane aligned with the clipping plane:
In case this was considered but dismissed, the use case is to use a clipping plane to check inside parts during design reviews, and then using dimensions to measure thicknesses along the clipping plane. The current workaround is to orient a flat surface and a clipping plane at the same time, and to use _CPlane _Object on the flat surface, then hide the surface.
Rhino 8 SR19 2025-5-12 (Rhino 8, 8.19.25132.01001, Git hash:master @ 57e3eb280b0f32cbe59f53a554be5e8ffa66fc36)
License type: Commercial, build 2025-05-12
License details: Cloud ZooWindows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
