@nathanletwory
Is there a reason why the animation raytraced recording is limited to 50 passes?
N
I don’t have Bongo.
I was talking about the native (I think) basic animation
I assumed it would take the render settings or the viewport, or the option you type on the command line. but none of that has an effect.
N
The NumberOfPassesForRealtimeDisplay should work. I’ll check tomorrow morning.
When I change the NumberOfPassesForRealtimeDisplay it doesn’t even produce the images.
N
I think I figured it out, see if it is the same on your side.
If you have chosen a viewport that is not visible on your screen, the record animation command is not going to work.
- It will take the displaymode of the viewport and not the one chosen on the animation
- if it is raytraced it will not do any pass
N
I think a solution would be to force the viewport to open.
A couple of more simple requests:
- remember the TargetFolder
- remember the number of passes
- allow naming the animation in the recording command
- consolidate the SetPathAnimation and the RecordAnimation commands
N
